Toyota Avensis T25 - Tns700 Sensor Signals Plug Pinouts?
Kendoakita
Hi to all,
I have bought a TNS700 to fit into my Avensis T Spirit Tourer (T25) and I believe that I have all the bits now to change the radio over to the TNS700 sat nav - but I don't have the 5 pin plug that fits into the TNS700 to add the speed and reverse signals. This plug and lead has to be added to the wiring. I kmow where to connect it to but I don;t know which pins it goes to on the TNS.
I can source the plug from Mr T - or even hard wire into the input pins but can anyone tell me which pins of the 5 have the speed signals and reverse connected please.
I've tried all the Toyota tech manual sites and I have the TNS700 installation manual but the pictures are not clear enough to see the pin details.
Many thanks in advance if anyone has the details.
Steve
What year is your Avensis?
55 T Spirit D4D 2.2
How much did you get the TNS 700 as you have the same car as me.
55 T Spirit D4D 2.2
I got the TNS700 off eBay from a breakers with a 2007 map DVD for £270. Out of a 2007 T25.
