T27 Power Mirror Fold/adjust Switch
Unpackedrope
Looking for a replacement part 183646 for the unit that incorporates the L-R rocker, the <> adjustment and the mirror fold switch. Fold works and adjust is intermittent. Suspect dodgy contacts on L-R but looking for replacement before I try a dismantle and cleanup.
Will try and upload pics when I get to a real computer. Thanks.
post-141044-0-02359000-1430071237_thumb.
post-141044-0-65747100-1430071278_thumb.
post-141044-0-72889100-1430071328_thumb.
Also have the same problem. Bought a replacement. Do you have any details on the replacement procedure? Some dos and don'ts....
Just pop it out, remove the cable and replace I guess. I had to remove the wee drawer to access properly.
Never did get a replacement though... Quoted £190! No danger - I'll send the windows down and adjust by hand I think...
Where did you get yours? How much?
Alternative is to strip it and clean the contacts - I think they'd being dirty is the problem on the L/R switch.
Thanks.
Found a used one from a used parts retailer about 20 Euros...
Thanks I will try a clean up first
