Rav4 - Install Rear Net/Dog Guard
Pictorial on fitting the Net/Dog Guard into the rear of the RAV4.
Time: 5 minutes
Ease: Very Easy to Fit
Firstly you need to un-clip the caps on the roof lining location holes. There is one on the left and one on the right.
Then feed the spring loaded metal bar into each side, once in it will click into place.
Then fasten the hooks to the retaining points on the boot floor, and pull the straps tight...
Once in place you cant then use the roller blind second part of the parcel shelf, as this cant access through the holes of the net. Make sure any valubale items are not left in the boot as they will now be seen.
