What Oil?
The Cav
Hi gang
can somebody settle the question of which is the correct grade of oil
for my Avensis 2.2 tdi
Mr Toyota in liverpool says 10/40 semi synthetic
Mr Castrol says 5/30 semi synthetic
Mr comma says 5/30 semi
and the manual for my car says 5/30
so what do you lot use???....inc brands if possible and the reason why
Hi gang
Mr castrol says 5/30 semi synthetic
Hi mate,
go with the manual and use 5w/30 it's right for the car and you won't go wrong with Mobil oil, by the way you can get 5ltr of Mobil from Asda it's on offer right now at £22.00, unfortunately your car takes just over 6ltrs so you will need to buy extra. Maybe buying 2 would be your best bet as 1ltr bottles are a rip off, anyway you can use the rest for topping up :thumbsup:.
Regards Pete.
Hi gang
Hi mate,
Regards Pete.
any good quality well branded 5w-30 semi or full synthetic will be ideal.
Just look up your model here http://www.opieoils.co.uk/c-879-products-for-my-car.aspx
Cheers
Guy
Thanks for the replies
Whilst googling oil on Thursday night
I spotted a google posting which proclaimed that Asda were selling
5/30 semi synthetic that was ideal for the Ford Zetec under their own brand name that had been reduced from £9 for a 2 litre bottle
down to £4.... after further investigations and going and comparing the specs of the Mobil FE
and the Asda own brand ....the specs by the way are identical i purchased
3x2 litres for a cost of £12
I have since gone to my owners manual to double check and this oil looks ideal
it meets all the requirements
btw they sell the oil in 5 litre bottles at £14 with the current large discount
so to add the extra 1 litre would have cost £18
what do you guys think?
would you buy/leave the oil alone as its not a major brand or try it
remember Asda buy this stuff in and just rename it
it prob comes from one of the major oil companies or maybe the likes of carplan or comma type oil suppliers
who knows
who knows
hi
before i got the auris i had a mondeo and purchased a 25 ltr drum of morris oil made for fords ie the exact spec as as Mobil fe which all ford main agents use.
as i had a half a can left i rang morris tec office to check if it was suitable for the auris engine
ive always found them very helpful. i was told that the oil i had was not ideal as Mobil fe is not SL/SM API grade
it would be no big diasters using it but they would not advise using it.
morris make three different fully synthetic 5w -30 oils two others are suitable for toyota petrol engines.
anyway i purchased Mobil ESP 5w - 30 from asda as its far the best (on test) and and stays in grade a lot longer than Castrol EDGE. plus as i am near asda no postage to pay, and the price very much cheaper than what Halfords ask for it.
peter
the vvti engine as not being
who knows
hi
peter
All own brand oils are made to a budget, so they just scrape by the specification tests, rather than exceed them. Normally they are ok for normal use, but there is a reason (other than paying for the name) that the branded oils are better
Get yourself down to Costco £41 for 20 ltrs Mobil 5/30 fully synthetic oil. Do a couple of oil changes and topups as well:)
my mechanic mate recons fully synthetic is a waste in my motor
because the mileage is high 102000 mls and also because its diesel he says its just a waste fully synth in a diesel
and also Mr T in Liverpool said fully synth is not necessary as its too thin and watery (if you get my meaning)
so I've put the Asda 5/30 semi syth in and will run that until the winter then I'll change it
was in home bargains today and they do a Gulf 10/40 semi synth in 4 lts for £8.95
so that's a premium brand for a good price obviously you would have to buy 2x4lts but for £17.98 that seems fair
Your mechanic is correct that you don't need a synthetic, but to suggest that you would as good performance from a more basic oil is just wrong. Also synthetics are not thinner. If a oil is a 5w-30 or a 10w-40, it is that grade. That is a measure of viscosity, nothing to do with the chemical make up of the oil. As for not using fully synthetic in a diesel, that's wrong too. Most new diesels are designed specifically to run on synthetic oils.
