Overheating Avensis
00avensis
hi guys
I have change the ecu temp sensor on my00 avensis and the fan will still not come on..
the fuses are ok as is the relay
there is no switch on the radiator
the switch i changed was where thebottom hose enters the engine it had two pins on it
ur help would be appreciated
Liam
hi guys
Liam
Maybe the fan motor is faulty. Have you tested it to see if will run?:)
I had this on mine. Check the fuses near your leg. A 10A one had blown . It has nothing on it to suggest it is to do with the fans so you might not have checked it. If it's not 10A then check them all.
