Relay Location ?
  • Please log in to reply
5 replies to this topic
#1 Gig-189
Gig-189
    Club Member
  • Registered Member
  • PipPip
  • 79 posts
  • First Name:Drinu
  • Gender*:Male
  • Toyota Model: corolla e12
  • Year: 2003
Posted 03 September 2011 - 07:40 AM
Hello Guys,
Can somebody point me the location of the relays & fuse for the front & rear foglights please, as I don't want to unclip the dash in vain.
Have something to contribute?
Sign in or register to start a topic...
Sign up to TOC Premium Membership To Remove These Ads
#2 oldcodger
oldcodger
    Guru Member
  • Registered Member
  • PipPipPipPipPipPip
  • 899 posts
  • First Name:oldcodger
  • Gender*:Male
  • Toyota Model: Corolla 1.6
  • Year: 2006
Posted 03 September 2011 - 09:26 AM
Hey,
According to the Haynes wiring diagram, the front fogs are connected via FOG LP Relay and fuse 15A FOG and the single rear fog via fuse 15A TAIL, No Relay.
As for their locations you need to check in your Toyota handbook
#3 Gig-189
Gig-189
    Club Member
  • Registered Member
  • PipPip
  • 79 posts
  • First Name:Drinu
  • Gender*:Male
  • Year: 2003
Posted 03 September 2011 - 10:00 AM
Hey, thanks for your reply. Found the front fog relay and managed to bypass the relay to check if they work and all good. So what I need now is to give supply to the relay from the stalk. This is because my car didnt have fog lights and am installing from the beginning. thanks again!!
Gig
#4 oldcodger
oldcodger
    Guru Member
  • Registered Member
  • 899 posts
  • Gender*:Male
  • Year: 2006
Posted 03 September 2011 - 10:14 AM
Gig
The rear fog light is just one bulb on the RH cluster, the LH is blank.
There are a couple recent-ish posts in this forum on how to modify the LH cluster to add a bulb and wiring.
#5 oldcodger
oldcodger
    Guru Member
  • Registered Member
  • 899 posts
  • Gender*:Male
  • Year: 2006
Posted 03 September 2011 - 10:24 AM
Hey,
You might find these scans useful as that combo light switch looks a complicated beastie.
#6 Gig-189
Gig-189
    Club Member
  • Registered Member
  • PipPip
  • 79 posts
  • First Name:Drinu
  • Gender*:Male
  • Year: 2003
Posted 03 September 2011 - 11:29 AM
My rear fogs are modified so I have to brake lights and side lights in each tail light. For the front foglights, I am going to get an auxiliary supply as I don't want to get in too much wiring and eletronics. All I need now is a foglamp switch and it will be all done :)
Thanks for your help
Not what you're looking for?
Register now, we have a huge community of enthusiasts to answer any questions you might have
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
