2003 Corolla Fog Light Installation
Conor94
I have a 2003 t2 corolla and wanted to install fog lights, theres wiring behind the grill covers for fog lights but i cant get the right kit for a 03 model does anyone know where i could get one or does anyone know if the lamps and wiring from a 2004 model will fit the 2003 model? I know i would just have to get the right grill covers then but toyota can supply them?
Toyota should be able to help.
It will require a relay, lamps and different indicator/light switch. One question is are your rear fog lamps switched from your light/indicator stalk?
Iv now got the lamps and iv changed the indicator stalk to the one with a front fog light switch but i asked toyota what bulbs the fogs take and they said HB4 but the bulbs dont fit, do you know if its HB3 i need?
Yes my rear fog light switch is on the indicator stalk.
Sent from my iPhone using Toyota OC
