Bluespark Cr-tech V1 Tuning Box
AlysAvensis
No longer require this.
Fits any common rail diesel engine with a 3 pin connector.
Comes with the instructions.
If you check their website you can get an idea of the gains it gives
http://www.bluesparkautomotive.com
My Avensis pulled a lot harder with this fitted and the settings are simple to adjust
£60 posted anywhere in the UK
Hi will this fit a 2006 2.0 d4d avensis pre facelift model 1cd-ftv engine
As long as the engine is common rail and has a three pin connector on the end it will work. I think all D4D's are common rail but check the wire plugged in if it has 3 wires it will fit.
Most Toyota D4D engines, late 2006> are 6 pin rail, you need to check if 3 or 6 pin
Where abouts do I check for the 3 pin plug?
Follow the injectors pipes down the side of the engine and locate where they fit onto the common rail. On the end of the rail, you will see an electrical sensor, that sensor will have 3 or 6 wires coming out of it
Kingo :thumbsup:
Cheers kingo
Can anyone point out where this is I can't see the rail there's plugs everywhere and a sponge type thing blocking the view.is it left or right of engine?sorry for being daft!
