Corolla Crank Sensor
StevieG62
Hi All Ive posted before regarding my problem with my 1.4 vvti corolla(02).Ive removed the crank sensor and done a resistance check,Im gettin a reading of 2121 ohms,does anyone know what it should be reading as ive no idea as to what the resistance should be.Thanks Steve
if your engine is 4zz-fe, the sensor must have 1630-2740 ohms when the engine is cold, and
2065-3225 ohms when it's hot
Thanks mate,sounds like my sensor is ok then,was kinda hoping it wasnt and was cause of my problem.Steve
