Vsc Warning Light And Trc Off
corollakidda
whilst drivin to work vsc light came on im due a service sooner rather than later,whilst drivin home light didnt come on,any ideas most appreciated :angry:
Had that happen to me once when i first got the car..... driving along and all the lights came on.... stopped, switched off, started again.... lights went out and have never been on since....
It could just be a slight blip in one of the sensors that throws all the lights on, but once it re-checks and all is fine the lights go off...
I think you only need to worry if they come on and stay on :thumbsup:
Happens to mine occasionally in wet weather (normally on opposite lock around an island :lol: ) but if the VSC light goes off after ignition off/on sequence, then nothing to worry about tbh.
Mick
used to happen on my clio every time i went over...i mean...10mph ;)
  • 6 months later...
Same problem here.
Could this be because I had 2psi difference in front type pressure? I read it somewhere that if there is a pressure diff. than it can foul the abs/tsc sensors since typres with diff. pressure will have different radius so different speed.
I have no error codes from ECU, I saw this problem right after I bought the car, but after I had new wheels it went away. Than I haven't seen this problem in the last 10000 miles. It only started again when I changed pressure, I went up to 36psi, but one of the front wheel did not like this and lost 2-3psi in 2000 miles.
I corrected pressure in all wheels, we'll see if it helps. Just I theory would be nice if other could confirm it.
Not sure about that theory...
I have slow puncture in one of my fonts... Last time i went for air it was at 21psi compared with the other being at 32psi...
Haven't had any warning lights come on...
yeah you're right. The light came up again. I checked again and I have no error codes at all. Any idea what it could be and how do diagnose this kind of problem?
