Cold Start Injector (help Wanted)
toby92
Hi, I'm having problems with my Toyota Corolla AE82. It suddenly died on me and now will occasionaly start then dies on warm up :(. I'v disconnected the cold start injector - there plenty of petrol one side of it, but when the ignition is turned on just a dribble comes out of it, do you think the injector is blocked?
Thanks hope you can help.
petrol or diesel ?
cheers
petrol or diesel ?
cheers
HI
It's petrol
thanks
You could measure the resistance of the cold start injector - normally about 2 - 4 ohms.
Also you can remove it from the inlet manifold, reconnect the harness and fuel line and test it off the car - place it in a container and connect the B+ and the FP terminals of the check connector under the bonnet - you should have a good fuel delivery and spray pattern.
Another possibility is the Cold Start Temp sensor being faulty - if it goes open circuit or there is a break in the wiring, the ecu will double the injection volume ( over what it normally is at 80 degrees C ) the engine will run rich and stall.
Hope some of this helps,
Mick
Mick
Hi Mick
Thanks for that will give it a try
