Sunroof Problem
Celica_XR9145
Have searched but couldn't find anything.
Yesterday i went to start the car and heard a tick then suddenly had no electrics.
The problem was the Battery terminal was f*cked so now thats fixed, the car start fine.
Since then the sunroof has stopped working. When using the switch, it doesn't make any sort of noises or clicks.
My first thought was a blown fuse but can't find the fuse for the sunroof.
Anyone know where it is?
I've went through the fuses in the engine bay and the drivers side kick panel but all fuses there are fine.
If it's not the fuse, anyone have any other ideas?
I read that if you disconnect the Battery, you have to do a reset function but dont have a clue how to do it.
If it helps, its a 'Webasto Top Slider 2' sunroof (can't tell if its aftermarket, it came with the car).
It's a 91 Trueno AE101 by the way. (i know its in the corolla section but im told the trueno is a 2 door corolla).
