Changing Corolla Steering Wheel
jonny__g
hi all
i was wondering is it possible to change my standard steering wheel on my 04 PFL corolla with the 't-shaped' ones on later and FL models? also, if possible, would i need any extra stuff to wire up the audio controls on the steering wheel as my current wheel doesnt support that function
cheers
j
or is there an existing audio remote 'plug-in' for the older style steering wheel? thats prob the only reason i was looking to upgrade the wheel as i miss that function from my old car. just wondered if this could be an easy upgrade to do
thanks again
j
I remember trying this on my facelift T3, I wanted a facelift t-sport steering wheel on it but it didnt fit. Airbags different and also the mouting, even the steering columns are different between pre and post
ok. what about adding steering wheel controls to my existing steering wheel?
has anyone added steering wheel controls to their corolla? i had a look under the plastic cowl and didn't see any spare wires, but perhaps there is a connector and the wiring could be bought to connect it to ste steering wheel buttons? any hwlp on this would be much appreciated guys
thanks
j
*Deleted*
I misinterpreted the question... sorry
You may need to get the wiring harness of a corolla that has the steering wheel controls, but i am not sure if it is seperate to the main loom.
If it is not then would you be prepared to remove your dash and change the whole thing?
Anyone got their steering wheel off atm to see if its part of the main dash harness?
