Corolla Gti Runing Probs
baby williams
hi there guys im new to here as recently bought a accident damaged gti 4age on a e plate but cant get it to start ive checked the fuel is comin through and ive got a spark she seems to turn like its gunna start but wont can anyone pls help !!!!
Hi mate,
Check to see if you distributor is positioned correctly. If it is loose maybe due to the crash damage, then twist it to the left to see if it then begins to start up. If it doesn't then try twisting it the other way. If it still doesn't work, put it back into its original position and look elsewhere.
