How To Install Clutch Slave Cylinder
TokeTillDeath420
Ok i just put a 93 LSD tranny into my 91 Turbo... Its on, all good. I go to put the clutch slave cylinder on the front side of the transmission and i cant compress the pin to align it properly between the release fork and the 2 holes on top to mount it.... Im goin crazy over here, help would be nice! =-D thanks!
try undoing the bleed screw, ive had it sometimes.
Well it didnt work, so i just gave up and bought a new one for 30$... While bleeding the clutch (Which really wasnt as difficult as ive read online) I noticed that one of the lines on top was leaking... I tightened it down as tight as it could go, Un seated it and re-seated it... It still leaks through the threads as well as where the nut is seated on the tube... I called toyota and that part has been discontinued... Any ideas on how i could fix this? (Without going to a junkyard and getting one used) Anyone else have this problem before? Thanks.
try to have a good look inside at the seat area of the cylinder and the end of the pipe, if either is scored then it will need replacing. if it is the pipe then you could get a replacement made for a few quid.
