Avensis Verso(Ipsum) 2004 Door Carpeting Removal
bear987654321
Hello,
I have a problem. Right back door's window won't come up. It just moves bit by bit. I seems like window came down from its hinges or something is stuck in there, because window motor is working just fine(when button is pressed it tries to move window up and make that tiny click sound, like it would be already fully closed. I was trying to remove carpeting to see what is wrong, but I couldn’t find a way to do it. I managed to remove plastic console (with button and cigarette ash tray), but it did not help, can’t see any screws. Does any know particular technique to remove carpeting, since I don't want to use brute force and make more damage than good :)
Cheers!
Sebastjan
