Reactivation Of Glass Breakage Sensor
americusparke
I just changed my toyota camry xle 2007 Battery and the glass breakage sensor will not activate
the owners guide was followed and I pressed the lock button on the remote control
then I waited 30 seconds until the LED began to flash
then with the tip of a key I tapped the center of the driver's door window
no warn away signal was activated. I tried this again but to no avAIL.
WHAT IS THE SECRET TO REACTIVATION
