Engine Troubles
THB_COMPRESSOR
Hi all
Had a problem with my comp, it seems to be running fine (idle, power, etc) but the last few days it's been running a lot louder.
I just serviced it and it was running like a dream, I only use Shell v power, supercharger oil changed but I still can't find the problem.
The only other thing I can think to do is to keep an eye on it until and if it gets worse do a bit more investigating.
Anyone had anything similar or any suggestions?
Many thanks
Tom
its not your exhaust is it box usually blows apart on top
I don't think it's the exhaust blowing it seems to be from the top of the engine maybe the vvti? Anybody have any idea of a t sport specialist or used anyone who knows their way around this engine pretty well?
Serviced it myself and put in Mobil 1 fully synth, took it away on holiday to Devon did about 300 ish miles ran like a dream. And about two weeks back it has been louder i thought maybe an intake pipe split something along those lines but when you drive it properly you can feel the top end of the engine shaking like as if something is out of balance
