Head Unit Not Powering Uphead Unit Not Lighting Up With Headlights And
asadrehman
Head Unit not powering up on Aygo Standard Head Unit
All of a sudden not lighting up with headlights and won’t power on. The whole Head Unit seems dead on power, nothing is powering
I’ve checked the fuse and its not the fuse.
bluetooth (CK3100) still works with the Speakers so there isn’t problem with the Speakers.
I think the bluetooth is powered by the Head Unit
Please advise,
Jan van de Wouw I think your the most experienced in this area
The CK3100 plugs in between the radio and the car, so if the Parrot still
works you've got power on both permanent and switched inputs.
Fact that your 12V-socket (not a lighter) still works proves my point: the permanent
power shares its fuse with the domelight and I haven't read that doesnt work either...
So it's probably the radio itself: doesn't have internal fusing...
You might try disconnecting it for half an hour or so to try to reset it...
