Parts
ConnyD
Firstly if I posting this message in the wrong saection I apologise. I required window washer water jets for and Avensis Hatchback 2.0 VVTi CDX 5DR
and I also need need a part but I have no idea what it's called! It's part of the window washer system and a small device which fits to the small rubber pipes and splits the stream into two for both sides of the windscreen. Anyone know where I can get the right parts. I'm reluctant to try the internet without a reccomendation as I was ripped off once.
Thank you
Hi ConnyD
My suggestion would be to take the old parts off the car, then go down to your nearest Halfords. They now have a surprising amount of (cheap) replacement washer bits, including "Y" junctions and jets.
A while ago I replaced a very blocked windscreen jet with a breakers one for £5, this lasted about 2 months before becoming blocked again. I then flushed out the system, and put in a Halfords generic one for about £3 - much better than the origional and cheaper !.
Toyota will always get you a direct replacement, but be prepared to spend mega bucks though.
Cheers
Bazzer
