Toyota Landcriser D4D Lc5 Start-Up Problem
johnsonjohnny4
hi to everyone seeing ths is my first post right here we go:
just got a 2005 landcriuser d4d lc5 from my toyota dealers less than a week ago and do about 100 miles since ive owed it mileage is 70000 full main dealer history problem is last couple of day when i start landcruiser from cold theys that much smoke out exhausts it like iam burnng tyres its shocking and took it out the other day took about 1 1/2 mile to clear up then it was fine no smoke what cause it to smoke so bad thanks for any help
johnny
johnny
hi mate
check with :
glow plugs as the first thing;
secondly if the glow plugs are in order then check with injectors.
Cheers/Igor
thanks for the reply ill send it back to main dealer ive only had it 5 days and ive done less than 150 mile and it come with full year warranty just put me off useing it today just incase it would damage engine and they were closed
thanks for help
johnny
  • 5 weeks later...
thanks had landcruiser back to main dealer and they say it normal for landcruiser to belt out smoke to high powered injecters be strange to drive down street with white and blow some in mirror plus it worse on cold orning and when i start it when its freezed over night the starter bangs before it start like someone hitting it with a sledge hammer and seem to jam sometime now but only on cold days though is this right what dealer or say as it back in monday for problem starter but it only stick on cold days so looks like ill get fobed of again
thanks for any advice love motor but hate smoke and problem
johnny
You're being fobbed off if the smoke is as bad as you say.
I'd ask a diesel specialist to have a look.
On the starter motor - is it manual or automatic?
it auto mate but it only bangs when starting on cold days same with smoke only bad on cold days
thanks for help
johnny
Hey brother.
I have the same model as you do, same year.
So, you are not the only one who experienced that thing. I'd also say it's normal
because i have it too, and my friend who owns also this model.
In the cold weather that is normal, just untill the car heats up. But, if it means that
much to you, you can press the button for faster heating up while you are still on
the parking. It is placed on the left side of the steering wheel, near the rear fog lamp
button. See in the user manual which is exactly so you do not press something else.
If you have an english version, so it's just the opposite.
By the way, you will notice on the cold weather if you enter garage your outside mirrors
will be covered in mist. In this case you press mirror heating which is near that button
i wrote about above.
About that 'bang' you said. That might be with batteries.
For these years my Prado spent more time in than out so when i wanted to drive it
my batteries were basically dead. Also had that problem of not starting good.
I bought new ones and now it works like a charm.
Cheers
