Oil Change - Level Surface Needed?
lestermester
Hi All,
If you're doing an oil change (in my case an E11 Corolla), can you get away with doing the oil change on a slightly sloping surface , e.g. a driveway?
If the nose of the car is pointing UP the slope, will this help with draining the oil or not?
Ideally, yes, it should be a flat surface, but can the above be done?
Thanks.
It will be ok as long as you recheck the oil (dipstick) on a level suface when you refilled it. :thumbsup:
