Advice : Landcruiser Juddering When Creaping Forward
johnsonjohnny4
ive got a landcruiser going in on monday for warranty work on blue smoke on start up but found out what the problem is as someone in other thread just sorted his with changing copper injecter seal ( leaking )
well while it in toyota ill see if they can do this its start judding ( jumping like a kangaroo :thumbsup: ) when creaping along in traffic but sometime it dosent do it is they some part on way out
thanks
johnny
thanks
johnny
ask them to check with injectors to prevent jumping.
cheers
They might be the same problem - ask toyota to check the injectors when they swap the washers. or it could be something like the egr valve gummed up
