Whats That Noise!
Adam786
I have a rattling noise coming from the front left suspension when going over even the most minor bumps at low speeds of around 10 - 30mph.. Its probably there at speeds over but the speed of going over the bump probably irons out some of the bump.
The suspension can get a bit crashy aswel sometimes on that side but the drivers side (right hand) seems to be fine on comfort and noise!
It cant be my link rod because I had that changed 3 months ago.
Check that a piece of spring hasn't broken and it's rattling around.
Is it there only on loose surfaces gravel broken tarmac etc?
YES! well not loose gravel because Id drive really slowly over that, But on roads with a bit of broken tarmac, like lots of potholes, I think if i drover over a cobblestoned road Id would be driven crazy with the ride on the left side and the rattling! But it is apparent on even small potholes and the right side suspension seems to just glide over with no fuss at all.
sounds like the link rods to me, mine is doing the same on my left wheel and i had mine changed less than a year ago.
sounds expensive :( how much did that cost you! and did it eliminate the problem??
