2002 Corolla Airbag Ecu Failure
finchy
Hi, my servce centre has advised that the airbag ECU has failed on our 2002 1.6 Corolla Spirit.
£50 for the diagnostic and a further £536 if we want to replace the ECU.
I'm a retired electrical technician so would like to actually look at the ECU, but does anyone know where this can be found on the car?
Could a used replacement just be plugged in, I'm guessing it would not be that easy!
Has anyone else had a similar failure, as far as I know, nothing obvious has happened to cause this.
Hi Derek and welcome to the club.
If you put your question on the corolla forum your sure to get advice.
