53 Yaris Tsport Headlights Problems
edli83
Hi All,
I am currently having some problems with my headlights and I was wondering if anyone could shed some light :-)
So 2 days ago, I went back to my car and both my headlights were not working, I changed the bulbs using Osram H4s and they seemed to work just fine.
However for the past 2 days only the left headlight is working properly, the right headlight is on but very faintly. This is accompanied by the blue full beam symbol on the dashboard being lit up (although its not lit up as brightly as it would be if my full beam was on.... what does this mean?)
After I drove around for 10minutes or so in the morning, it seemed to resolve itself for the first day but I had the same problem this morning and it didnt resolve itself....
Any thoughts?
Could be a bad connection somewhere, has the car previously been fitted with high powered headlights, if so the problem could lie with the stalk switch or relay. First try the connectors at the lamps to see if there's any sign of burning or if they're loose.
Sorry I can't be of any more help.
Clean and remake the earth connections to the body. They can be seen under the bonnet on each side of the car
Regards Geoff Peace
