X Reg Avensis D4 Vvti Wont Start
Nuub
Hello everybody, I am new to this forum.
My Avensis, after 3 years of service has refused to start. The MIL light is off, but it goes sporadically on. When the MIL is on, the engine will start for approximately 5-10 seconds, then it stalls. I have tried resetting, reading error codes (there arent any). Does anyone recall such symptoms? My car is a 2000 Avensis with 1AZ FSE D4 petrol engine.
Regards, Nino
Sounds like a dodgy ignition switch.or a bad connection on between switch and ecm any dashlights missing wen it wont start?
All other lights are on, even when the ECU light is not on, so I assumed the switch is OK. But thanks for the advice, I will check it in the weekend.
Just check if the efi relay is pulling in when this fault occurs located in the fuse box under the bonnet
Hi, I checked the EFI relay. It is working, as well as the Inj and EFI II relays. I found a death bat near the injector driver ECU. I believe it has chewed on some of the wiring.
Update: It seems like I found the problem. I was the fuel pressure sensor. With sufficient pressure on the injector rail the sensor was short-circuiting the 5v supply from the ECU. These 5 Volts supply most of the sensors, the throttle motor and apparently some of the internal ECU electronics. While the injector rail was under pressure (right after starting and a while afterwards) the sensor was disabling most of the ECU functions. Does anyone have an idea where I can find a cheap spare (according to toyotaDIY the sensor costs 270 Euro).
I hope this is going to be helpful to someone.
Regards, Nino
