Service Help
sohail579
My sister who also has a t sport on a 02 plate is now due for a service which I will be doing myself.
What's the recommended oils and spark plugs should I use the car has done 80k drives perfect I was thinking I should change the lift bolts would you agree?
Normally I would use Mobil 1 oil.. Have I been going wrong?
Hi sohail
A lot on here use good oil Castrol , Mobil etc 5-30 full syn denso are good plugs i have read some where that you
change the lift bolts every 60,000 miles :)
I use Mobil fully synth 5 - 30w. NGK's or Denso are good. Would recomend using a toyota origonal filter though.
thanks for the info guys.. also i would like to as are there any good tutorials for changing the lift bolts?
