Water Leaking Sound Problem, Yaris Verso 1.4 D4D
Slobodan Djurovic
Please help.
Last 5 days noticed sound of like "water leaking" somewhere in dashboard,
and that happens only while car is moving. When car stops, this sound disappears.
Motor checked and everything is ok..and didnt notice any drop of water in the car.
Tnx
Check coolant levels. Low coolant levels mean you will hear water being moved around when the engine is running.
Cheked. Coolant level is on max.
Tnx anyway
