Rear Diff
baz1631
Hi guys, can anyone tell me what tool/s I need to loosen the filler plug on the rear diff.Mines extremely tight and I dont want to ****** up the plug. Mind you I doubt it hasn' been off in a few years, also wanting to change the oil in the gear box .Is it the same size plug as trhe rear diff? any help would b most appreciated , as usual :thumbsup:
See pinned section, Baz min, Techy Information Hints and Tips.....covered by Anchorman including required tools.
Big Kev :thumbsup:
There is a great DIY for this pinned on the tech section (assuming its a 4.2)
http://www.toyotaownersclub.com/forums/index.php?showtopic=110842&st=0&gopid=1004201&
You will need a 10mm Allen socket for the rear diff, I find the wrench usually needs a gentle thump with the palm of your hand to loosen.
The gearbox is 24mm.
Don't forget your front transfer box if you are doing the rear diff, its also on a 2 year change and separate to the gearbox.
