Inlet Manifold
riprap
Its a known problem on some vehicles caused by a loose baffle/divider - IIRC, unbolt the throttle body and you should be able to see the baffle - some tips out there on the net on how to remedy the loose baffle without having to go to the expense of fitting a new manifold.
Mick
