Warning Lights Removal
JonD4D2008
Hi just cleaned the egr valve on my avensis d4d 2008 seems great since clean..
Can anyone tell me please can i remove the warning lights manually (trc vsc and engine management).
Is this a garage job or do you still think there could be a fault any advice will be welcomed many thanks..jon
Just turning the ignition on and off should clear the lights, it may take a couple of attempts so i would leave the car for a couple of hours and try again then, mine were coming on due to me having a piggy back box fitted, so i removed it and they cleared after a couple of attempts, may also be a dodgy wheel sensor though if it doesnt clear, just be patient with it
Regards phil
