zetor 5 Posted January 2, 2013 Share Posted January 2, 2013 Does anyone know the locatiuon of the hand brake switch and wire colours on the Auris? I can see a module of some sort behind the handbrake but I don't think this is it, when I unplugged the connector it made no difference to the hand brake light in the instrument panel, the wire on this were green and red, I cannot see if there is a switch infront of the handbrake without taking the whole panel off. Quote Link to post Share on other sites
Grumpy Old Man 0 Posted January 3, 2013 Share Posted January 3, 2013 I am sorry that I can’t help you with the location of the handbrake switch, but will just point out that the light doubles up as a brake fluid level warning as well.Maybe if the light is on all the time (guessing that’s why you want to find the switch) you need to check the fluid and the level sensor first? Quote Link to post Share on other sites
zetor 5 Posted January 3, 2013 Author Share Posted January 3, 2013 I am fitting a head unit and I have to connect a light green wire to the power side of the hand brake switch, this is so video can only be played whislt the car is stopped and hand brake on. Quote Link to post Share on other sites
SirQuiksilver 0 Posted April 27, 2016 Share Posted April 27, 2016 Did anyone get back to you on this Zetor? I'm currently in the exact same situation with Pioneer headunit. I can start pulling stuff apart but would be greatfull if someone who has already done this could take a photo of exactly what I should be looking for! On 02/01/2013 at 7:16 AM, zetor said: I am fitting a head unit and I have to connect a light green wire to the power side of the hand brake switch, this is so video can only be played whislt the car is stopped and hand brake on. Quote Link to post Share on other sites
johalareewi 271 Posted April 28, 2016 Share Posted April 28, 2016 On 02/01/2013 at 7:16 AM, zetor said: I am fitting a head unit and I have to connect a light green wire to the power side of the hand brake switch, this is so video can only be played whislt the car is stopped and hand brake on. Or you could just hook the light green wire up to +12V or ground, depending on what the head unit wants. Quote Link to post Share on other sites
zetor 5 Posted April 28, 2016 Author Share Posted April 28, 2016 I had no luck working out where to connect the green wire so didn't bother with the video function, sorry can't be of any help. Quote Link to post Share on other sites
