Floating Plastic Covered Seat Track Through Belt Buckle Base. Why?
(Floating toothless seat track through belt buckle base, 1 each seat. Why?)
1991 2wd US Federal wagon front seats. Plastic covered flat steel stock. Only attached at rear end by a pivot bolt to center tunnel. Other end just slides through seatbelt buckle mount between mount's bolt and buckle. This track has to be unbolted to remove seat from the car. Then it can be slid right out of the seat. It doesn't seem to do anything I can see. Why is it there?
Link to post
