Hesitation On Hard Acceleration
scottyd74
Hi ther I got a 2003 celica vvti 140 problem I have is when hard accelerating the car feels like its holding back service been done maf cleaned throttle body stripped and cleaned no vacuum leaks kinda getting stuck now any help or advice would be appreciated cheers
Scotty
Anyone that can help?
Where in the rev range do you think it starts hold back?
Does it have an induction kit or any alterations to the airbox?
No car is standard as is air box new air filter fitted on service I'd say its between 3.5 to 5.5 thousand rpm you notice it
Cheers scotty
You reach max torque at about 4300 revs (I believe), but it should still feel fluid past that point.
Have you tried resetting the ECU?
