Loud Rattling Noise From Offside Top Of Engine.
Lusty
Got a loud rattling noise coming from offside top of engine when she's idling.(D4D t3-s)
The steering isn't heavy so I THINK the bearings in the belt tensioner pulley wheel are knackered as she drives fine.
Anyone had similar experience of this?
Thanx in advance.
The only time my avensis had a rattling sound was the air con unit was buggered. I could not find a cheap one at the at the time so I got a belt from the avensis without aircon fiited (t22) which by-passed the aircon pully.
does the sound go quieter when you put the aircon on?
Go with your instinct. Remove the belt and look for play in the various pulley-wheels. It should be fairly obvious which is it fault - To convince yourself that you're right, run the engine with the belt off. Just for a few seconds though.
