Permanent Live Feed?
gedc
how do i get a permanent live feed into cabin to power taxi radio? 2014 avensis
Direct from the Battery with an in-line fuse is the simplest option. There are plenty of rubber grommets on the firewall giving access into the passsenger compartment for the cabling.
For your Taxi Meter / Taxi Radio / Data head a stand alone feed direct from the Battery.
5/10amp is max you will need.
Look past the passanger side strut, you should see a gromit, carefully make a hole and this will leave straight behind the glox box.
  • 1 year later...
do you know where the pulse is on the 2010 model , there was one on my last avensis 57 plate
Yes I do, I fit Taxi Meters, The Aquila Range. Dealer in West Yorkshire.
