Help Needed From Helpful Toyota Picnic/ipsum Owner - Which Coloured Wi
jedsalisbury
Hello, do you own or drive a Toyota Picnic/Ipsum? If so could you look under the bonnet and identify a wiring setup for me, please?
I acquired a second hand Toyota Picnic last year and a few weeks later realised that the air conditioning wasn't working. Looking under the bonnet I discovered that the cable loom that goes to the aircon compressor had at some time in the past been yanked out of the connector. leaving
the connector and the cable's uncovered wires still inserted in gromits inside the connector attached to the compressor but with the cable dangling. I managed to pull the 3 pins out of the connector and reattach them to the loose wires. But the problem is that I don't know which wire goes to which gromit socket in the connector. I don't want to try the 6 combinations by trial and error in case I blow too many relays/fuses.
It is proving impossible to find a wiring diagram or manual for the Picnic, and my Toyota mechanic is having the same problem.
If I could look under the bonnet of a Picnic with aircon I would find the answer very quickly. However, finding a tame Picnic owner in Salisbury is proving impossible, so I'm hoping someone out there in
the Toyota Owners Club might be willing to check their Picnic's or Ipsum's aircon wiring and let me know which of the 3 wires goes where. Please can you help?
Jed.
