Sunroof
markg6r
Hi one help
I've got a new relay
New motor and new switch
It just works for a second and nothing. Help
Sent from my iPhone 5s. using Toyota OC
Check the wiring , there may not be enough power getting through or you need to check the travel of the sun roof checking for any foreign objects and greasing the slide.
The slide is ok I think
It's the slide is like in a case looks like a small chain in it
Is it clear of dirt and debris and lubricated with a quality grease.
Yes from what I see I've roof it taking away do I can see it maybe it is the not getting enough power
Or need too reset ?
A friend of mine just read your post and he emailed me this.
By removing the motor I could see that one of the brass coloured tubes that holds the drive cable had come out of the housing.
It was just a case of releasing the gear the motor connects onto to give me enough room to line the brass tube back up with the housing.
I placed a pair of mole grips on the gear and turned it manually until the sunroof was completely lowered.
Cleaned and greased it and it worked fine.
I hope it helps...
Thanks a million will try it as soon as i can
Got round too it and one of the chains on the copper tube are broke so need new one ;)
Thank again
Toyota heaven
