1.4 D4D Very Hard To Start When Hot
gixxert
hey
just coming from work today my 2006 1.4 d4d corolla died.
no engine management light on
it wouldnt start straight away but did 2hrs later.
plugged into diagnostics and showing no engine fault
checked the cat,not blocked
changed all relays beside the Battery
changed high pressure fuel pump and fuel rail
bypassed fuel filter with non return valve
car will start when left for a while
had a few spares in the garage
car has high milage (300000 km)
cam / timing chain not rattling
i would imagine diagnostics would show crank or cam sensors if chain had stretched??
turbo seems ok (no movement on the turbine)
what is the pressure at the fuel rail on cranking?
If anyone can shed a bit of light on this, i would be very grateful :disgust::disgust::disgust: :disgust: :disgust::disgust::disgust:
I have come across two remedies whilst being on this forum.
either starter motor or scv valves and a update on ecu.
To check if starter, get someone to push the car, get to about 5MPH and jump in and try starting. If it starts then your starter motor is NOT WORKING if it doesent start then its NOT the starter. (i know it seems weird but thats how it is)
