1995 Camry Le
meetat18c
If they are anything like other models the grill isn't meant to be removed - The surrounding panel should be unscrewedwhich will lift the grill away with it. The grill covers, whilst separate mouldings,are clipped in plae by fixings only accessable when panels are removed.
Hope this helps
Thank you. I was hoping that wasn't the case but it does help. Appreciate you response. At least now I can get on with installing new Speakers.
Cheers
