Map Nav
Tangolegs
Hi Folks, new to Auris, bought mine today in fact. When I press 'map nav' response is ' system not installed'. Guessing here but does the answer lie in purchasing a Toyota map Disc and installation is via the CD player slot?
Which Auris do you have - first or second generation, trim level??
sounds like you have a car with Touch but not Touch & Go. Go is the satnav bit & is extra hardware - it can be dealer fitted but iirc will cost you~£700.
Frosty balls. HSDT4. That's as much as I can tell you at this point.
Heidfirst, that sounds logical. Many thanks
would have thought that a T4 would have had Go ex. factory ... no doubt Frosty will be along shortly with his knowledge of standard year/trim specification.
If you join & look on MyToyota it should give you your vehicle's spec. https://my.toyota.co.uk/#sign-in
So it is a first generation Auris, which was done in two specs - T4 and T-Spirit. According to the January 2012 brochure, both specs came with the Toyota Touch multi media system, but the Touch & Go (which incorporated sat nav) was an option.
Thank you guys, both. Your answers do tie in with the situation here, and in my novice status I do appreciate your help.
Only Toyota I've ever owned before was a Starlet in the 80's. Not sure I'll be splashing out £700 to upgrade.
Many many thanks, I'm sure I'll be on this forum again soon seeking help.
