Are all 4AFE engines interchangeable?
Chris84
Hello,  I'm Chris, long time Carina driver,  thanks for taking the time to read this.
First off can I apologise if this question has been asked before,  I tried to find it before I posted this.
OK, I have a 1994, Carina E, 1.6
The engine has had it so I'm looking for a replacement to swap like for like.  I can't bring myself to scrap it.
My question is will any 4AFE engine fit, ie from a 1998 corolla or an early avensis?  Or are there differences I need to be aware of?
Any advice or tips on this job are welcome.  Also, if anyone knows where I can get a good condition replacement engine please get in touch.
Chris
Plenty of sources to identify a Tcar with a 4A-FE.
2sav
I know the larger 7A;FE is non-interfere and after a general search, so is the 4A-FE. There are minor difference - mainly with the ancillaries.
You need to look at sites like http://www.japan-parts.eu/toyota - you can look at models and compare parts and check part numbers.
As 'breakers', all Toyotas (of this older age..) seem to be stripped of all oily bits & containered either to Belarus/Afghanistan or Africa!!
An engine will not lie around long.... I see them (whole cars) appear on Gumtree as 'Spares or Repairs' ... this is probably your best avenue, m8
2sav
Thanks for the replies,
The reason I was asking is that I have found a potential engine but its coming from a corolla G6R.  I believe it was fitted with a different exhaust manifold.  I was just trying to determine whether any other changes may have been made that might catch me out when I come to fit it.
