2006 Toyota Aygo needs a lot of help!
LearnEveryDay
I have a vehicle suffering from the following:
P0917,
P0907
P0808
U0100
Which should I troubleshoot first?
Hi!
Are there any other symptoms? When did this happen and what were the conditions? Is the vehicle not able to drive right now or was it a one-time thing?
The last code is about communication with ECM, were any works done before this happened, especially somewhere in the battery's area? When was the last time the Battery was replaced? There are cars that tend to give a lot of errors at once when the Battery starts to go or it's not charging properly. Don't know about Toyota though, BMW definitely is known for this.
P0917,
P0907
P0808
U0100
P0917 means there is an electrical malfunction with the gear shift position circuit, likely caused by damaged electrical components or broken wires.
P0907 code means there is an issue within the vehicle's transmission gate select position circuit often due too wiring or rarely, the PCM.
https://www.engine-codes.com/p0908.html
U0100 stands for Lost Communication with ECM/PCM
if your issue is due to a faulty wiring harness you'll probably find all the other codes will clear
On 7/28/2018 at 10:28 AM, Byzii said:
Hi!
The last code is about communication with ECM, were any works done before this happened, especially somewhere in the battery's area? When was the last time the battery was replaced? There are cars that tend to give a lot of errors at once when the battery starts to go or it's not charging properly. Don't know about Toyota though, BMW definitely is known for this.
I have not replaced the Battery since I bought it last year august...work was only done on the gear... We changed the disc and plate twice because it kept getting spoiled.
The guys that worked on it said the clutch disc and plate were bad,so we changed it
Shortly after,it started giving problems and we changed the clutch and disc again
The Battery has not been replaced or any other electrical components apart from a couple of fuses
How would I determine that the wiring harness has issues?
If the vehicle skid connector has 26 pins instead of 46, does it mean it does not have ABS?
I mean the Brake Actuator Assembly?
The factory schematics for diagnosing U0100 is a bit confusing.
I need some help please.
