Auris 2014 TS Match PP 41DSP install
qettyz
Hello,
Previously i changed my speakers to Alpine ones and got little bit better sound to my car. Still i was not very happy. Today i went and bought Match PP 41DSP plug & play amplifier.
External Image album in case of these forum images will disapear: https://ibb.co/album/dgzLgF
Amplifier is marketed to be plug & play. I bought Toyota version and it came with Toyota wiring harness. Amplifier get everything it needs from the wiring harness, separate power cable is not needed (at least 20A fuse to standard car audio system is required).
Match PP 41DSP is quite small
On the back side is different Toyota version list. Each number is different configuration on the DSP what can be changed with two buttons.
Let the tear down begin, i had some help from Toyota-Tech.
20190303_114828.thumb.jpg.bebcacb2433a868f5cc87304852340ac.jpg20190303_114820.thumb.jpg.ee5c7e49ae891c021b5693266a43328f.jpg
20190303_114500.thumb.jpg.7984eff6f1a3cec3d46b31c8a3295171.jpg20190303_114638.thumb.jpg.3c02aead64b529bb2dd60f9ee038328a.jpg20190303_114914.thumb.jpg.09750d40d16f02425a253ca5114ea1c8.jpg
Audio unit was held with four 10mm screws.
Match wiring harness goes between these two connectors and stock audio unit.
There was perfect slot behind the glove box. top of air filter for Match. With little soft padding i was able to secure it to the place without fear of rattling noise or it moving around.
20190303_123831.thumb.jpg.9c288922c6ae3800221fe71fee40eb34.jpg20190303_123842.thumb.jpg.0eabe9c88d438fed94795b0c6f5271b8.jpg
With these pros and cons its good to note that i have changed my stock Speakers to Alpine SXE-17CS 6.5 kits previously and DSP program is done for stock Speakers. I found some installation notes from some BMW install saying that you can easily change stock ones to little better with this one without fear that DSP is then way off.
I could image that stock Speakers could benefit this maybe more than these Alpines.
Pros:
+ much clearer stereo "feel"
+ sound is more level from whole range from low to high
+ deeper low end
+ super easy plug & play install
+ rear speakers sounds better
Cons:
- DSP levels cannot be programmed, you need to buy PP 62DPS for that
- stock Audio unit seems to cut bass low when volume is tuned way up, DSP wont compensate that
- 4 x 35W 4ohm RMS is not gonne blow your mind
Something what came to my mind while installing this, Match Toyota wiring harness can be bought separatly and would be awesome help for installing some another amp what can take high input for example Audison Prima AP4.9bit. Of course you need to modify it and route power cable from Battery etc and NOT use power from main unit. Those Toyota Match wiring harness are 24,90€ here at Finland, easily worth it.
Edit:
Some measurements
Audison Prima AP4.9Bit    198mm x 45,50mm x 134mm
Match PP 41DSP              185mm x 44mm    x 124mm
Audison would about ~ also fit to the same slot behind the glove box!
Oh well. Big note to myself and to this thread: That slot cannot be used. There is moving part for air intake from outside or to circulate inside air. Amp forced inside air circulate on and didnt have to drive alot to note that.
Gotta find better position then.....
Found good position for unit from driver side next to the obd socket and fuse box. There was free M6 hole and i screwed unit with loctite. Good clearance from pedals and wheel column. 🙂
  • 5 months later...
Just seen this.... Looks good, I've done exactly the same, in exactly the same car recently:
- changed the Speakers (pioneers in back, Gladen in front)
- bought a Match PP41 amp
I hope I can find the slot next to fuse box you indicate to place the amp. Otherwise it wil be just laying in the glove compartment, but I think your solution looks neater.
I will be installing it this week.
  • 1 year later...
Hi, I am wondering to upgrade my sound system to T27 Avensis with this same amplifier. I have already upgraded my Speakers to Alpine. Do You recommend this upgrade? Is it worth it?
OP last visited April 7 2020, i doubt you will get the answer.
Auris-Frankie last visited 29min ago.. And if You read his post You will see that he has bought same amplifier also.
