Engine idling high 2004 Roadster
jackrmee
I know this is very difficult to diagnose, but anyone have any ideas on best place to start?
She's been sitting in the garage for a good while, so I gave her a full service (filters, oil and plugs). She's running ok, but is idling around 1500-1700 revs. Is this too high?
I've also noticed the throttle pedal is sticking slightly. When I jump in for the first time of the day, I need to opush my foot down hard to release it, as it seems to be stuck somewhere. Once it's loose, it's fine for the day. Not sure if it might be linked.
Engine management light is also on, but has been like that for ages, as the power steeering pump was gone. I fixed it, but didn;t turn the light off, so may be still on for that, as I don't have OBD tool to check or turn it off. If anyone can recommend me an OBD tool I will get one of them and have a look.
Thanks in advance 🙂
Old models won't support any fancy features on bluetooth OBDll So I recommend that orange one with a cable
My avensis also starts up 1500 but steadies ~ 700 when wormed up
Disconnected Battery (negative only (should clear the code)
Better wait for code reader
Costs ~ £10 and It works 5 years now
You might want to buy a fancy one
Edited by Amatér
Additional stuff
