Beeping
Patrick1234
My auris done a single beep with no warning lights on the dashboard. This happened on two occasions on the same journey. There is a problem with the abs sensor but it shows up very rearly and when it does show up there is a single beep followed by the abs warning light. In this case there was no dashboard lights followed by the beep. The passenger seat was empty.. would could this be??
Probably speed camera warning. Go into settings and disable speed camera alert.
Like Jonmartin said, is a speed camera warning from you GPS navigation. You can disable it from your media settings.
