Yaris 1NZ and 2NZ Transmission Differences
chrome24
Hi all,
I'm over in Australia and am having trouble sourcing an automatic transmission for a 1.3L 2008 Yaris.
I've been told most of the 1.3s are common across the Yaris range (NCP90 and NCP130 Series) but haven't found any so I wanted to see if the 1.5L auto transmission can be used in the 1.3L Yaris?
From my quick research, the 1.3 and 1.5 are geared differently. (1.3 = U441E Transmission, 1.5 = U340 Transmission). Has anyone attempted this changeover before?
Toyota Owners Club is UK based.
Europe didn't have the second generation Yaris (XP90 - 2006-2011) in 1.5L NZ series form. Also the 1.3L NZ series engine was rep!aced in late 2008 with the 1.33 NR series engine and this continued into the third generation (XP130 - 2011 onwards).
Send me a PM with your vin i can then have a look - the 1.5 uses a larger flywheel iirc the starter is in a different position
