Weird bump in new aygo wheel trim
wadi16
hi all,
Have a brand new aygo from the dealership.
I randomly noticed a weird bump in the trim today, but no scuff or scratch marks anywhere near it so it wouldn't have been a kerb etc
Any ideas? Anyone else had this?
Could be the edge of a pot hole
Sent from my G8341 using Tapatalk
something has hit the wheel trim as you can clearly see a scuff on the tyre next to the distorted area
Did you try to remove the hubcap to check if it was properly clipped onto the rim?
If there are no scratches, maybe it comes from the moulding and it was slightly deformed upon delivery. I have hubcaps on mine and the quality is not that good.
If you enlarge the picture you will actually see one large distortion of the wheel trim and also a smaller one, as eygo said the tyre is clearly scuffed. So it’s obvious you’ve come into contact with some sort of object.
