rob21 0 Posted December 11, 2020 Share Posted December 11, 2020 hi im rob and i am new here it seems that the windscreen washer is a common problem with the avensis and yes i am having problems with mine my brother and i changed the front washer pump still no joy . i don't have a owners manual so i don't know which fuse it is for the front washer or if there is a relay for it he tested the fuses with a meter but the windscreen wiper worked when pressing for washer any help with location of fuse or relay would be great thank you it is a 06 plate hatchback thank you Quote Link to post Share on other sites
Stivino 130 Posted December 11, 2020 Share Posted December 11, 2020 Use a voltmeter or a 12V bulb/old car horn to see if you have 12V at the motor. Or, switch the plugs from the front and rear pumps on the bottom of the washer bottle to determine the fault. Quote Link to post Share on other sites
rob21 0 Posted December 11, 2020 Author Share Posted December 11, 2020 thank you stivino will give it a go tomorrow Quote Link to post Share on other sites
